I designed a PCB for the oscillator, PICAXE, DAC, op-amp and regulators, for this I used an OPA388 "zero-drift" op-amp which has extremely low offset and drift, perfect for this application. I also added a few SMA connectors so I can get a secure connection to my oscilloscope to verify the oscillator output, reference voltage and control voltage.
There's a REG101 5v linear regulator in an SOT-23 package on the bottom side for the PICAXE, DAC8830 and OPA388 as they only draw a few milliamps. For the 3.3v supply to the oscillator I'm using a TPSM84203 DC-DC converter which has a greater than 90% efficiency in a package the size and shape of a TO-220, a linear regulator here would likely need a heatsink whereas the DC-DC converter operates cool even right next to the OCXO.
Its a 4 layer PCB and I'm using both inner layers as ground planes, I found a German PCB manufacturer called Aisler who made 3 of my PCB (minimum order) for €11.17 and the boards are excellent quality!
One minor mistake I made was the order of the pins on the TRS jack for the PICAXE serial connection, you would think the pins are in the same order as the connector that goes into it but the tip and ring pins are not in the same order physically which connected the PICAXE serial in from the cable to ground on the board and vice versa, luckily nothing was harmed and I managed to put together some audio connectors to reverse the connections.
The precision and stability of the control voltage is beyond what I can measure with my scope.
Oh and it has 3 pins for power in and 10MHz out so I can stick it into the breadboard.
