Hi Guys (& Dolls),
I have another issue this time with an LCD monitor model AOC 919Vwa+ conntected via DVI.
Upon powering up the picture is abnormal - jittery and rather broken up but it gradually settles to display a usable screen with several horizontal white lines along the lower part of the screen when the picture stabilizes. The image is also displaced slightly upwards so that calibrating the touch screen I have added will give me reference points going beyond the upper margin of the screen. I am including a photo of the screen but do have a short video to show how it actually lights up on powering it on (https://mega.nz/#!BIYliRAb!zODNa96e_STA5TL-5BqWpMRUIAxAMx0uxwdoiWoIZSQ).
I did check the inner electronics and no swollen capacitors are visible.
This is part of a set-up of an electronic organ I built that has a dedicated motherboard, videocard + 2 monitors (VGA and DVI) each fitted by me with a touch-screen, onboard sound card, 3 sata hard drives, optical drive, 3 manual MIDI USB keyboards and a MIDI pedal board I made using an Arduino module . I have had to use a USB hub to connect touch screens and a wireless network adapter.
I hadn't used this organ at all for some 6 years and before played it sparingly as I went along building it. Only lately did I start to play it again having had to reinstalled Windows 7 ultimate because my previous installation was shutting down or going into sleep mode often, sometimes as often as some seconds and eventually led to corruption of the OS as it shut down during a long windows update. Now the set up is stable and no more unexpected interruptions.
I am using the same cable and software & drivers seem to be up-to-date. The issue may well coincide with the re-installation of windows and swapping of the several USB connections to get everything working properly.
Any ideas of what could be wrong with this display?
Mark
Mark
