another odd battery problem
  • Thread starter William Sommerwerck
  • Start date
W
William Sommerwerck
Any nicad experts out there? This is an interesting one. (I'm not looking for
a "solution", just an explanation, out of curiosity.)
Many years ago I bought the Sony TCD-D3 DAT Walkman, which fits a fat pocket.
I made a few live recordings, as it was a lot less bulky than a processor/VCR
system.
The other day I pulled it out to confirm it was still working. I'd bought two
extra batteries with the unit, and put all three on charge. They all charged
up, but the third battery wouldn't power the unit. Its end-of-charge voltage
was nearly 7V (though these batteries are nominally 6V), and the other two
charged to about 6.4V.
When I put the third battery on charge again, it rose to about 7.5V, even
before charge was terminated. I let it sit overnight, and it self-discharged
(?) to about 5.5V. (The others //did not// show significant self-discharge.)
It still wouldn't power the unit.
"Obviously" this battery pack is defective. I'm just wondering if anyone knows
what's going on.
It's no big deal, as I have two good packs (which are 20+ years old!), and the
AC adapter. Also, the packs are "external", so I could (if I wanted) saw open
the pack and replace the cells. Or simply throw together a homebrew pack to
fit the DC jack.
Just askin'.
"We already know the answers -- we just haven't asked the right questions."
-- Edwin Land
W
William Sommerwerck
"Dave M" wrote in message
Nicads have historically been plagued by "dendrites", or crystals of
conductive material (probably cadmium, but not sure) between the
electrolyte layers in the cells. This creates a low resistance leakage
path inside the cells, rendering them incapable of retaining a charge
for any length of time or putting out their rated voltage. Dendrites are
responsible for the so-called "memory effect" that nicads are famous for.
There have been several procedures published on the net as to how to
remove dendrites (search for "nicad dendrites"). One process involves
charging a large electrolytic capacitor (eg, 500uF) to a few hundred volts,
discharging it through the bad cell, then running the cell through a couple
of charge/discharge cycles.
I assume the discharge is + to +.
I built a little box for this process several years ago, and it seems to
work.
It consists of a transformer, a voltage doubler, and a large capacitor.
A push-button switch triggers an SCR that lets the capacitor discharge into
the bad cell (sort of like a one-shot CD ignition).
I'll give this serious thought. The worst that can happen is that the battery
is ruined. (!!!) Thanks.
I'm still curious about the battery's unnaturally high voltage.
Phil Allison
"William Sommerwanker "
self-discharged (?) to about 5.5V. (The others //did not// show
significant self-discharge.) It still wouldn't power the unit.
knows what's going on.
** You are describing the standard "old age" failure mode of most NiCds.
1. The internal resistance of some or all the cells in a pack rises - often
dramatically.
2. The energy capacity drops by a large factor.
3. The pack will not hold charge due to internal leakage.
4. The terminal voltage is depressed, from 1.25V to about 1.2V per cell.
A single overheating event can result in the same outcome - whether by
overcharging or otherwise.
Reason ?
NiCd cells have a small amount of water in them - lose that and the cell is
stuffed.
.... Phil
mike
I'd be careful. Energy is proportional to the square of the voltage.
I use 12,000 uF and 10-20V, mostly because that's what was handy.
You want to hit the sweet spot where you instantly vaporize the dendrite,
but generate no more heat than necessary. Too little energy or too
much energy is worse than just right. That's why suggestions to
use a car battery are bad. Little chance of getting it just right.
Way too much chance of getting enough energy to explode something.
500uF AND 200V is WAY too much.
The process leaves the hole in the insulator/separator.
The field density is high and the dendrite wants to grow back.
And discharge thru the hole causes the high self-discharge rate.
I've had a lot of success restoring 40 year old F-NiCd's for
uses that don't require more than a few days storage life.
But, these days, you can get equivalent capacity in a pair of
AA NiMH cells.
Don't discount the safety issues with high voltage.
The "experts" who look at only part of the problem will call me an idiot,
because 200V probably won't kill you.
Two problems with that..."probably" is great for statistics, but
provides little solace to your family when you're the ONE who died.
And B, the shock isn't the only problem.
I've got scars where the muscle contractions that thru me across the
room caused me to rip my arm open on some sharp object in the path.
Luckily, I haven't fallen and cracked my head open on the furniture...
yet...
Eye Protection is a MUST. Sparks fly.
Phil Allison
"William Sommerwanker the Over Snipper form HELL "
Fine. Nothing new.
** All new to YOU fuckhead.
But why the high voltage?
** When on charge - point 1 applies.
Cease charge the pack and the voltage drops almost immediately.
V = I x R ..........
Wot an idiot.
..... Phil
W
William Sommerwerck
"Phil Allison" wrote in message
Fine. Nothing new.
** All new to YOU, fuckhead.
I've killed men for less than that.
I wasn't expecting you to repeat common knowledge about rechargeable
batteries.
** Cease charge the pack and the voltage drops almost immediately.
** V = I x R ..........
** Wot an idiot.
You don't see it, do you? Of course not.
The same thought crossed my mind. The question is... why should a cell's
voltage -- which is supposedly determined by the battery's chemistry --
essentially double (assuming only one cell is bad)? Why should the cell become
a sort of electrochemical chameleon, trying to match the voltage across it?
