Robert Baer said:
The results are way off.
The sense resistor is for a peak current of 240mA, the time when the
gate is supposed to turn off.
The current in the 1mH inductor is supposed to be a linear ramp from
zero to 240mA, and take about 2.3uSec for an inductor supply of 100V
(8.9uSec for 30V, 5.0uSec for 50V and 1.0uSec for 200V). These values
are from a real circuit, and seem to be reasonably close to calculated
values using E=-L*(dI/dT).
The current never gets into the ampere region(!!).
Furthermore, when the FET turns off, there should be a large, narrow
voltage pulse (not some variable wierd-shaped and slow rise waveform).
What is wrong? Code follows:
You are an idiot, that's what is wrong.
What does C3 and D2 do in your circuit......?
You think it's some clever sort of voltage doubler type thing, don't you?
Ask yourself what happens when C3 has charged up to some voltage and you
switch the mosfet on.... That's right, D2 becomes forward biased and C3 gets
shorted out through D2 and the mosfet. You get a BIG spike on your current
sense resistor.
Fortunately the LT1619 ignores this because it has leading edge blanking.
So..... that pisses that one off.
You get the drain waveform you get because at start up you are charging the
output capacitors. Do you need a slap around the head to understand that
one.
Another one pissed off.
If you run your circuit for a while so things come into regulation you get
double pulses because you haven't bothered to compensate things properly,
you just pulled values off the data sheet. I'm sure you don't know how.
Probably won't work without a reasonable load anyway.
It's unstable.....
Your last one pissed off.
Let's face it, you design shit because you don't know shit. You also draw
shit circuits. I don't care if you've got something on the bench that works,
it might do but....... it's shit.
I'm the sort of poor sod who gets the job after you've been fucked off and
then I have to fix your shit which is in production and top bosswank, your
bum chum, cannot believe that there is more to it than changing the value of
RZZZ111A.
Tell me where you work so I don't have to go through it again.
And stop blaming your inadequacies on other people. That's my tactic.
Mike and Helmut have missed the bit about your concept of a voltage doubler
but the rest of the advice they are giving you is good. These are two
exceptionally tolerant (and clever) people.
I am not so...... **** You.
Here's my contribution...... I will warn you that I have waved my wet finger
in the air to get a result. If I was pushed then I'd do the job right and
provide supporting information.
Unfortunately you come across as a bleating wanker so I'm not going to waste
my time.
Have a crap day.
DNA
Version 4
SHEET 1 1416 740
WIRE -464 432 -464 -48
WIRE -464 544 -464 512
WIRE -464 576 -464 544
WIRE -272 0 -320 0
WIRE -272 32 -272 0
WIRE -272 192 -320 192
WIRE -272 192 -272 112
WIRE -272 224 -272 192
WIRE -272 432 -272 224
WIRE -272 544 -464 544
WIRE -272 544 -272 512
WIRE -160 -48 -464 -48
WIRE -160 32 -160 -48
WIRE -160 144 -160 112
WIRE -144 304 -320 304
WIRE -144 336 -144 304
WIRE -144 432 -144 400
WIRE -144 544 -272 544
WIRE -144 544 -144 512
WIRE -80 144 -160 144
WIRE -80 224 -272 224
WIRE -80 304 -144 304
WIRE 80 -48 -160 -48
WIRE 80 80 80 -48
WIRE 80 544 -144 544
WIRE 80 544 80 368
WIRE 304 -48 80 -48
WIRE 304 144 240 144
WIRE 304 144 304 -48
WIRE 352 432 352 -48
WIRE 352 544 80 544
WIRE 352 544 352 512
WIRE 528 -48 352 -48
WIRE 576 192 512 192
WIRE 576 224 240 224
WIRE 576 224 576 192
WIRE 576 272 512 272
WIRE 576 304 240 304
WIRE 576 304 576 272
WIRE 608 224 576 224
WIRE 720 224 688 224
WIRE 768 -48 608 -48
WIRE 768 96 512 96
WIRE 768 96 768 -48
WIRE 768 144 768 96
WIRE 768 304 576 304
WIRE 768 304 768 240
WIRE 768 432 768 304
WIRE 768 544 352 544
WIRE 768 544 768 512
WIRE 800 -48 768 -48
WIRE 896 -48 864 -48
WIRE 896 432 896 -48
WIRE 896 544 768 544
WIRE 896 544 896 496
WIRE 992 -48 896 -48
WIRE 992 432 992 -48
WIRE 992 544 896 544
WIRE 992 544 992 512
WIRE 1088 -48 992 -48
FLAG -464 576 0
FLAG 512 192 DRV
IOPIN 512 192 In
FLAG 512 96 DRAIN
IOPIN 512 96 Out
FLAG 512 272 ISNS
IOPIN 512 272 Out
FLAG 1088 -48 VOUT
IOPIN 1088 -48 Out
FLAG -320 0 VOUT
IOPIN -320 0 In
FLAG -320 192 VFB
IOPIN -320 192 Out
FLAG -320 304 VERR
IOPIN -320 304 Out
SYMBOL voltage -464 416 R0
WINDOW 0 -120 48 Left 0
WINDOW 3 -120 68 Left 0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName VSUPP
SYMATTR Value 15V
SYMBOL res 752 416 R0
WINDOW 0 -72 45 Left 0
WINDOW 3 -69 70 Left 0
SYMATTR InstName RSNS
SYMATTR Value 0R22
SYMBOL ind 512 -32 R270
WINDOW 3 70 65 VBottom 0
WINDOW 0 65 58 VTop 0
SYMATTR Value 1mH
SYMATTR InstName L1
SYMBOL voltage 352 416 R0
WINDOW 0 38 41 Left 0
WINDOW 3 40 66 Left 0
SYMATTR InstName VBUS
SYMATTR Value 100V
SYMBOL cap 880 432 R0
WINDOW 0 42 24 Left 0
WINDOW 3 41 47 Left 0
SYMATTR InstName C2
SYMATTR Value 4n7
SYMBOL diode 800 -32 R270
WINDOW 0 59 30 VTop 0
WINDOW 3 62 37 VBottom 0
SYMATTR InstName D1
SYMATTR Value MUR460
SYMBOL PowerProducts\\LT1619 80 224 R0
WINDOW 0 -159 -162 Left 0
SYMATTR InstName U1
SYMBOL res -160 416 R0
WINDOW 0 -56 49 Left 0
WINDOW 3 -58 76 Left 0
SYMATTR InstName R3
SYMATTR Value 100K
SYMBOL cap -160 336 R0
WINDOW 0 -57 20 Left 0
WINDOW 3 -58 42 Left 0
SYMATTR InstName C1
SYMATTR Value 220p
SYMBOL res -288 416 R0
WINDOW 0 -74 47 Left 0
WINDOW 3 -76 71 Left 0
SYMATTR InstName R2
SYMATTR Value 12.4K
SYMBOL res -288 16 R0
WINDOW 0 -77 45 Left 0
WINDOW 3 -77 71 Left 0
SYMATTR InstName R1
SYMATTR Value 5E6
SYMBOL res -176 16 R0
WINDOW 0 -47 48 Left 0
WINDOW 3 -47 74 Left 0
SYMATTR InstName R4
SYMATTR Value 10K
SYMBOL res 976 416 R0
WINDOW 0 39 56 Left 0
SYMATTR InstName RLOAD
SYMATTR Value 100K
SYMBOL nmos 720 144 R0
WINDOW 3 56 61 Left 0
SYMATTR Value Si9420DY
SYMATTR InstName M1
SYMBOL res 704 208 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R5
SYMATTR Value 10R
TEXT -472 616 Left 0 !.tran 0 250u 10n 10n
