Robert Baer
The results are way off.
The sense resistor is for a peak current of 240mA, the time when the
gate is supposed to turn off.
The current in the 1mH inductor is supposed to be a linear ramp from
zero to 240mA, and take about 2.3uSec for an inductor supply of 100V
(8.9uSec for 30V, 5.0uSec for 50V and 1.0uSec for 200V). These values
are from a real circuit, and seem to be reasonably close to calculated
values using E=-L*(dI/dT).
The current never gets into the ampere region(!!).
Furthermore, when the FET turns off, there should be a large, narrow
voltage pulse (not some variable wierd-shaped and slow rise waveform).
What is wrong? Code follows:
Version 4
SHEET 1 1000 680
WIRE -400 352 -400 -96
WIRE -272 80 -272 32
WIRE -272 224 -272 160
WIRE -272 256 -272 224
WIRE -272 432 -272 336
WIRE -176 528 -176 304
WIRE -176 608 -176 592
WIRE -160 -96 -400 -96
WIRE -160 144 -160 -16
WIRE -144 304 -176 304
WIRE -144 336 -144 304
WIRE -144 608 -176 608
WIRE -144 608 -144 480
WIRE -80 144 -160 144
WIRE -80 224 -272 224
WIRE -80 304 -144 304
WIRE 80 -96 -160 -96
WIRE 80 80 80 -96
WIRE 80 608 -144 608
WIRE 80 608 80 368
WIRE 80 640 80 608
WIRE 304 -96 80 -96
WIRE 304 144 240 144
WIRE 304 144 304 -96
WIRE 304 304 240 304
WIRE 304 384 304 304
WIRE 352 224 240 224
WIRE 352 320 352 224
WIRE 480 -112 480 -160
WIRE 544 320 352 320
WIRE 592 -160 480 -160
WIRE 592 80 528 80
WIRE 592 80 592 -160
WIRE 592 128 592 80
WIRE 592 224 592 208
WIRE 592 240 592 224
WIRE 592 384 304 384
WIRE 592 384 592 336
WIRE 592 416 592 384
WIRE 688 224 656 224
WIRE 688 352 688 224
WIRE 688 464 688 416
WIRE 704 224 688 224
WIRE 896 32 -272 32
WIRE 896 224 768 224
WIRE 896 224 896 32
WIRE 896 288 896 224
FLAG 80 640 0
FLAG -400 432 0
FLAG 592 496 0
FLAG 480 -32 0
FLAG 896 352 0
FLAG -272 432 0
FLAG 688 464 0
FLAG 528 144 0
SYMBOL voltage -400 336 R0
WINDOW 0 -46 6 Left 0
WINDOW 3 -70 87 Left 0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value 15V
SYMBOL nmos 544 240 R0
WINDOW 0 56 67 Left 0
WINDOW 3 -115 41 Left 0
SYMATTR InstName M1
SYMATTR Value IRF7343N
SYMBOL res 576 400 R0
SYMATTR InstName R1
SYMATTR Value 0.22
SYMBOL ind 576 112 R0
WINDOW 3 30 -1 Left 0
SYMATTR Value 1mH
SYMATTR InstName L1
SYMBOL voltage 480 -128 R0
SYMATTR InstName V2
SYMATTR Value 100V
SYMBOL cap 880 288 R0
WINDOW 0 -45 -7 Left 0
WINDOW 3 -85 49 Left 0
SYMATTR InstName C4
SYMATTR Value 4700pF
SYMBOL diode 704 240 R270
WINDOW 0 32 32 VTop 0
WINDOW 3 0 32 VBottom 0
SYMATTR InstName D1
SYMATTR Value MUR460
SYMBOL PowerProducts\\LT1619 80 224 R0
SYMATTR InstName U1
SYMBOL res -160 320 R0
SYMATTR InstName R2
SYMATTR Value 75K
SYMBOL cap -160 416 R0
SYMATTR InstName C1
SYMATTR Value 15nF
SYMBOL cap -192 528 R0
WINDOW 0 -27 -6 Left 0
WINDOW 3 -55 62 Left 0
SYMATTR InstName C2
SYMATTR Value 220pF
SYMBOL res -288 240 R0
SYMATTR InstName R3
SYMATTR Value 12.4K
SYMBOL res -288 64 R0
SYMATTR InstName R4
SYMATTR Value 49988K
SYMBOL res -176 -112 R0
SYMATTR InstName R5
SYMATTR Value 10K
SYMBOL diode 704 416 R180
WINDOW 0 24 72 Left 0
WINDOW 3 -98 -6 Left 0
SYMATTR InstName D2
SYMBOL cap 656 208 R90
WINDOW 0 0 16 VBottom 0
WINDOW 3 34 9 VTop 0
SYMATTR InstName C3
SYMBOL cap 512 80 R0
WINDOW 0 -63 4 Left 0
WINDOW 3 -84 60 Left 0
SYMATTR InstName C5
SYMATTR Value 5.0µF
TEXT 528 224 Left 0 ;N009
TEXT -312 664 Left 0 !.tran 0 25uSEC 0uSec 0.001uSEC
TEXT 448 408 Left 0 ;N006
TEXT 376 344 Left 0 ;N007
Version 4
SHEET 1 1000 680
WIRE 80 80 80 -96
WIRE 80 608 80 368
WIRE 80 640 80 608
WIRE 304 -96 80 -96
WIRE 592 80 528 80
WIRE 592 128 592 80
WIRE 896 32 -272 32
WIRE 896 224 896 32
FLAG 80 640 0
FLAG -400 432 0
FLAG 592 496 0
FLAG 480 -32 0
FLAG 896 352 0
FLAG -272 432 0
FLAG 688 464 0
FLAG 528 144 0
SYMATTR InstName V1
SYMATTR Value 15V
SYMATTR InstName M1
SYMATTR InstName R1
SYMATTR Value 0.22
SYMATTR Value 1mH
SYMATTR InstName L1
SYMATTR InstName V2
SYMATTR Value 100V
SYMATTR InstName C4
SYMATTR InstName D1
SYMATTR InstName U1
SYMATTR InstName R2
SYMATTR Value 75K
SYMATTR InstName C1
SYMATTR Value 15nF
SYMATTR InstName C2
SYMATTR Value 220pF
SYMATTR InstName R3
SYMATTR Value 12.4K
SYMATTR InstName R4
SYMATTR InstName R5
SYMATTR Value 10K
SYMATTR InstName D2
SYMATTR InstName C3
SYMATTR InstName C5
SYMATTR Value 5.0µF
