Bill
I'm designing the analog front-end for a device that measures EEG
(approximately 0.5 to 50 Hz, 10 to 1000 uV peak-to-peak). I'm using a
good instrumentation amplifier, and a good input RC network that does
not degrade the CMR.
Once in a while, I also need to measure (estimate) the impedance of
the electrodes (silver/silver-chloride).
It would be perfect if I could disconnect the input RC network (the
one just in front of the instrumentation amplifier) while I measure
the electrode impedances.
Would you guys dare to insert, in series with the input lines (the
ones that carry microvolts of differential voltage), a good analog
switch like the ADG1636?
(http://www.analog.com/en/switchesmultiplexers/analog-switches/adg1636/products/product.html)
If not, why?
Mismatch (that could degrade the CMR) between Ron's can't be a
problem. I'll have 1 % 6.04 kohm in series with each input line. Not
even the Ron itself is a problem. The ADG1636 has around 1 ohm of on
resistance.
Off resistance can't be a problem, either.
Linearity of the on resistance as a function of the analog voltage
across the switch can't be a problem either, because Ron is much lower
than 6.04 kohm.
I'm only worried about noise. Would it be a problem? The datasheet
says very little about noise (it mentions 0.007 % THD+N and shows a
graph). My instrumentation amplifier is an INA121UA (with 20
nV/sqrt(Hz) @ 1 kHz).
Would you dare to use such an analog switch in this application?
Any of you has experience in this field?
Thanks a lot.
Bill
If not, why?
resistance.
than 6.04 kohm.
Thanks a lot.
Bill
