I have a 3 motion detecter setup that I feel like I've got most everything worked out with. Common, hot and ground are all parallel up to the motion sensors and each has it's own relay after that ties back into common. I'm using three 120V AC DPDT relays (Omron MY2-UA 120VAC), where the coil is rated at 120VAC and the contacts are rated at 5A 240VAC and 5A 28VDC. I'm not using flood lights so the path of travel is from motion sensor to relay to ground. I suppose it's not necessarily travel with AC, but my question is: On a circuit that has a breaker rated for 20A, and no lights to consume energy in the circuit, after the coil is triggered will it continue past 5A and burn up my relays? Insert drawing for the sake of pictures.
Platforms
Content
