Power boy
I have a linear ccd signal input, the ccd analog output shift out
pixel's voltage at max frequency of 1MHz. According Nyquist the raw
signal's bw is 500kHz.
check page 6 in below:
http://www.zygo.btinternet.co.uk/tcd1304ap.pdf
I need to build an afe + adc circuits.
I want to increase the dynamic range. The spec says noise is 2mV. Who
knows the measurement bandwidth? whatever, just say, 2mV.
I picked an adc, super good, with bw of 16MHz. I want to do an AC
coupled, bandpass afe. I calculated the variable gain should be 0-60dB
or less. I want to limit my afe's bw, or limited harmonic for the ccd
analog inputs. Remove the inband white noise as much as possible. but
I want to consider the in band ripple will generate the uncertainty. I
want to control the in band analog uncertainty within 0.1%. How many
harmonics should I choose? To do a reverse Fourier transform might
sovle this problem but I am far from the textbooks.
I guess I need 500kHz * 15th = 8MHz. how about the ripple introduced
by the 1st to 15th harmonics for square wave?
