Hi !
I‘m a student in carpentry and I‘m designing a piece of furniture, a very big expandable desk. Like, go big or go home kind of project. It has been dubbed „Deskimus Prime“. I would very much appreciate a little help considering the electronics needed to make it move. I want it simple, nothing digital or computer controlled, just motors and endstop switches. If you can help, it will be greatly appreciated!
The desk:
I have only drawn simple sketches of the desk, since I need to determine the dimension of the motors and components before I make a proper technical drawing.
On the first image is the desk setup closed and locked. On the other, it is fully open. When it is closed it is about 2m wide, 1.3m deep and 2m high. When open, about 3m wide, 2.3m deep, and 2.8 high. Not final dimensions, but somewhere close.
It will be made of solid Elm wood, so it will be a bit on the heavy side. When it is full of stuff it will be even heavier. So I‘m thinking each motor should be able to move/lift min of 100kg. Except the one for the lid, it can be smaller, like 20kg capacity, and the one for the backside should be bigger, maybe 200kg. Since it will be this heavy, the motors can‘t move to fast. I‘m thinking 1 – 2m / minute, but since I haven‘t completed the design it is hard to say exactly.
The transformation
A simple top-view drawing of it closed (left) and open (the other left)
· Button is pressed
· Lid rolls back. Stop.
· Units 3 and 4 move out together. Stop.
· Units 2 and 5 move to the sides simultaniously. Stop.
· Units 2 and 5 are lifted up. Stop.
· Unit 1 is lifted up. Stop.
· Units 3 and 4 move to each side. Full stop.
For this I‘m gonna need 9 motors. As previously said, the one for the lid can be small, the one for the backside (unit 1) around 200kg lifting capacity, and the other 7 with a lifting/moving capacity between 100-150kg.
Also, I live in Sweden, outlets here are 230V.
If you have read through everything, thank you ! I hope you can leave some pointers in the comments, whether it‘s help with the project, or someway I can improve my post. I will update as I make progress.
Thank you !
The desk:
The transformation
· Button is pressed
Thank you !
