Ok, so its been about 1 - 2 years i've been researching and have found what i was looking for. I need some help in designing and building it so here goes:
I plan on building a project which allows me to change the amplitude and frequency of a waveform. This is then fed through an output which is capable of handling high currents at low/high frequencies. How the design and components are laid out i have still to determine.
For now, I plan on using Quartz Crystal Resonator Oscillators. I think if these were applied with a current it should be used as the waveform's frequency but i'm not sure if i need 2 for the maximum and minimum threshold frequency. Also these will be used for the output frequency to determine how far it will travel.
Hopefully this project can get started soon.
