I'm working on a project that will produce ultrasound waves through a piezo tweeter in short bursts (target is 105dB).
I'm planning to use a "DIY function generator" kit that will produce the input signal I want. Its adjustable and I intend to tune it to a square wave of 8VPP (max) and 22KHz. The generator handles between 9 and 18 V of DC supply input.
The problem I am facing is how to amplify the generator signal (8VPP and probably low current) to drive a 200W piezo tweeter. I wasn't able to find out the max V/I that the tweeter can handle. The tweeter operates between 5KHz-50KHz, 200W max, 105dB, 4 or 8 Ohm.
I'm looking for a low cost solution, so don't want to use a home/car multi-channel amp.
I plan to drive as many as 4 or 8 tweeters.
Can this tweeter be driven to the max using some discrete transistors / inductors on a breadboard? I'm not interested in sound quality (won't even hear it) other than the tweeter to spit out an ugly 20+ KHz signal at about 105dB.
