N_Cook
This is probably the circuit, split primary is used , ZD is a 5V zener
checked ok
, V are 1N4007 checked ok, 2.2uF,100V polyester for high C unpolarised, ,
pnp BC214 emitter to top , 94R is 2x 47R in series
view/message source, may have equi-spaced font to read the ASCII image
240V
| mains primary
|C
|C------- 120V -----------------------------------------|
|C |
| 47R |
| ___ |
| -|___|-| |
| ,´ |< BC214 |
100R,25W| ,´ / ------- |
|----- / |-------| | V 2.2uF , 100V |
.-. _|_/ --- --10uF | - || |
| | V_A 10uF--- --- V ---||---| |
| | | | ___ | - | || .|. |
'-' |--------- -|___|- ZD | V | | |
|----| | - | | 94R,10W |
| 2K7 | | '-' |
|TIC236D | | | |
0V | |
120V
An exiting commercial 600W audio amp, runs perfectly happily if this triac
stuff is bypassed.
I'm assuming the triac circuit protects the amp from over current but I find
it confusing. Plenty of gain on the pnp, all Rs check out ok and triac
checks ok tried out in a dimmer circuit.
Running up the transformer , without any load, with this cct via a variac
there comes an ac voltage where large peaks are produced at the primary and
overvoltage at the secondary and nasty saturation type noise from the
windings. Checked waveform on a scope via isolation transformer and
monitored over 35R resistor placed in series with the primary. Peaks are one
a cycle (about 3mS of 20mS UK mains) but not at peaks , troughs or inflexion
point of the mains and amplitude of the peaks maybe as much as twice the
mains peak to peak .
Swapping the TIC to a lower rating TIC226D the amp (no load) works fine, no
nasty mechanical noises.
Swapping the triac to a 25A, 600V the same effect is observed. I'm assuming
that something is causing the triac to cut , once a cycle, when a high
voltage is across the transformer and the inductance of the primary is
generating these peaks, but what is the likely culprit?
checked ok
240V
| mains primary
|C
|C |
| 47R |
| ___ |
| -|___|-| |
| ,´ |< BC214 |
| | | | ___ | - | || .|. |
| 2K7 | | '-' |
|TIC236D | | | |
0V | |
120V
stuff is bypassed.
