I have a function generator and I would like to take the output and amplify it for input to various types of motors (AC, DC, stepper, etc.) or other gizmos for experiments at the bench at home. I would like to have the amplified voltage variable (set via a dial) up to 50 volts with up to 10 amps or so and follow the signal output from the waveform generator (sine, square, triangle, ramps, or whatever I choose to output). The frequency range needs to go from DC up to around 10 kHz (frequency determined by waveform generator output but from 0 to 10 kHz). The amplifier will be powered by standard 115V 60Hz power. Any ideas on the circuit design of such a device? Specs are somewhat flexible depending on doability and cost. Thinking of some sort of op-amp and power mosfet or transistor circuit? Please help.
Platforms
Content
