Hello everybody,
Problem description:
I have a 4 layer + 2 power plane mixed-signal PCB with SMD components
on one side and I would like to route the digital signals on Mid Layer
1+2 and the quiet analogue signals on the Top and Bottom Layers.
Altium version: Altium Designer 6.7
Layer Stackup Buildup (no blind and buried vias)
Top Layer
GND Plane
Mid Layer 1
Mid Layer 2
Power Plane
Bottom Layer
I placed the digital signals in a 'Digital' Net Class to be able to
assign a routing layers rule to these digital signals - routing layers
enabled for this rule are Mid Layer 1 and 2. Priority=1.
The analogue signals where also allocated to an 'Analogue' Net Class
and assigned to another routing layers rule with the Top and Bottom
Layers enabled. Priority=2
I also have a default rule with all the routing layers enabled.
Priority=3.
Behaviour:
For some reason when I run an Auto Route->All the signals in the
digital Net Class are not routed. Signal fan-out vias are generated
but then the connections on the inner layers are not made. It's not a
problem of the router not having enough space to route the signals,
the router simply stops. I could try to route the signals by hand but
there are too many of them and it's clearly not the point of using an
autorouter.
When I try to route the 'Digital' Net Class separately by going to
Auto Route->Net Class... the same problem happens (on a board with no
pre-routes). The autorouter doesn't do anything. Running an Auto Route-
Strangely enough if I replace the fan-out vias with pads and then I
run Auto Route->Net Class... the connections are made.
Am I missing something, or is this a bug?
Hope somebody out there is able to help!
Best regards,
Patrick
Top Layer
GND Plane
Mid Layer 1
Mid Layer 2
Power Plane
Bottom Layer
Priority=3.
Behaviour:
autorouter.
Fan out->Signal Layers also doesn't help.
Best regards,
Patrick
