[allegro15.7]import netlist error(ERROR: Property requires avoltage.)
Shawn Chen
Below is a quote of the log file, include the error part.
I'm using spb 15.7 and try to import the netlist.txt file and meet
this problem.
This netlist was export from a brd file. I don't have the schematic,
only have netlist.txt and device file, where can I modify these error?
Any suggest are appreciated.
Quote:
Allegro NETLIST IN Log File
VGA_IN_RED7 ; U1.W11 U19.28
VGA_IN_RIN ; C130.1 FB52.2 R126.2
'VGA_IN_RIN-C' ; C130.2 U19.14
'VGA_IN_RIN-CONN' ; FB52.1 P8.1
VGA_IN_SOGIN ; C129.2 U19.8
VGA_IN_SOGOUT ; RP38.6 U1.AF6
'VGA_IN_SOGOUT-R' ; RP38.3 U19.24
VGA_IN_VSIN ; P8.14 U19.71
VGA_IN_VSOUT ; RP38.8 U1.Y6
'VGA_IN_VSOUT-R' ; R129.1 RP38.1 U19.22
VTTDDR ; C50.1 C51.1 C52.1 C53.1 C55.1 C56.1 C57.1 C58.1 C318.1
C319.1 ,
CP30.5 CP30.6 CP30.7 CP30.8 CP31.5 CP31.6 CP31.7 CP31.8
CP32.5 ,
CP32.6 CP32.7 CP32.8 CP34.5 CP34.6 CP34.7 CP34.8 CP35.5
CP35.6 ,
CP35.7 CP35.8 CP36.5 CP36.6 CP36.7 CP36.8 RP25.1 RP25.2
RP25.3 ,
RP25.4 RP26.1 RP26.2 RP26.3 RP26.4 RP27.1 RP27.2 RP27.3
RP27.4 ,
RP28.1 RP28.2 RP28.3 RP28.4 RP29.1 RP29.2 RP29.3 RP29.4
RP30.1 ,
RP30.2 RP30.3 RP30.4 U43.3 U43.5
VTTDDR_REF ; C316.1 U43.6
VTTVREF ; C68.1 C313.1 C314.1 C420.1 C421.1 C422.1 C423.1 C424.1
C425.1 ,
P2.1 U1.AD27 U1.AG26 U1.AG31 U1.J26 U1.K26 U1.W30 U42.3 U42.5
VTTVREF_REF ; C311.1 U42.6
$PACKAGES
$A_PROPERTIES
VOLTAGE '1.8V'; 'U20'
VOLTAGE '1.8V-3.3V'; 'U19'
ERROR: Property requires a voltage.
SIGNAL_MODEL 'TQFP65P1600X2200_100'; 'U19'
SIGNAL_MODEL 'DEFAULT_RESISTOR_562OHM_1_2'; 'R199'
VOLTAGE 'NA'; 'C402' 'C403' 'C265' 'C286' 'C295'
SIGNAL_MODEL 'DEFAULT_CAPACITOR_2.2e+008pF_1_2'; 'C294' 'C295'
SIGNAL_MODEL 'DEFAULT_RESISTOR_124OHM_1_2'; 'R221' 'R223'
SIGNAL_MODEL 'DEFAULT_RESISTOR_84.5OHM_1_2'; 'R220' 'R222'
SIGNAL_MODEL 'DEFAULT_CAPACITOR_47pF_2_1'; 'C127' 'C128' 'C130'
VOLTAGE '2.5V-3.3V'; 'U16'
