ako: A Kind Of (aliasing components)
Harald Kapp submitted a new resource:
ako: A Kind Of (aliasing components) - Stepping device paramerts or stepping complete device models
A component model is referenced in LTSPICE by either referencing an element from a library or by adding an explicit .model statement into the schematic. When a circuit needs to be simulated with different devices or different device parameters the reference or the .model statement needs to be changed every time.
When using library models the library may need to be edited to change device parameters.
Enter the (undocumented) directive ako: (A Kind Of):
  1. Change a model parameter:...
Read more about this resource...
