hello everybody
I am new on here so will appriciate any advice
anyway:
I was playin with my dashboard, cluster etc - took it all off... thgouh - I wanted to install some LEDs etc into my cluster and needed to know where do I get positive and negative feed - though:
I connected the side connectors for each oher
letf to the right and right to the left socket (interesting is that it got in..! (arrowns point to them)
below is one of the speedo units taken off the board - it has stepper motor and couple of diodes
and all units taken off
and tachometer
now, my question is though - I do not know if it was the reason or not - but - I DO NOT get light into the cluster - 0V in the conectors for bulbs when I turn on LIGHTS on steering wheel -
the only that works on the cluster connected is: OPEN DOOR indicator, LOW BATTERY (I have 9.6V as my car is without engine at the mmt for a while), ANTI-LOCK indicator. thats about contorls. now the CLOCK WORKS, and backlight of them work UNTIL I TURN ON HEADLAMPS - then the clock light turns off... strange, isnt it??!
then - interior lamp works, HEADLAMPS and tailights also...
my question is - could have I damaged the cluster by connecting those two side connectors wrong? :/ (btw no fuse / bulb is blown...
just theoreticaly - WHAT WOULD GET BURNT/BLOWN FIRST - if volts went where they shouldnt ? diodes? transistors?
I did some check on diodes on the board - there are 3 - with my multimeter - had it set up for signal ON for continuity - I get beep only on one diode from those three - though I get some Ohm reading on all of them (they are identical M1 writing - and read 570Ohms or so,,) .. is it correct? or once I do net get continuity beep - it means that diode is blown regardless of resistance reading shown...? or some diodes will do beep (if set to beep) some show resistance reading (if set to OHM reading..?
I can post a wiring technical diagram of the cluster unit - I am not a proffesional so not much of use for me...
anyway:
and tachometer
