Hi Mike,
Thanks for the advice. Could you suggest a cheap processor that will do
this? As mentioned I have consdered pic processors but was confused
with the huge number of these devices and the limitations many had in
being able to output at 115kBaud. My main concern is that I can program
the processor without having to buy expensive development kits and so
on. Also the outputting of data at 115kb requires some tricky
programming. Do you have any examples of software that does this?
You can do serial in/out with any processor just about if you are
able to 'bash the bits', I might add, you can do that at way above
115K if you really wanted to without much trouble at all.
What do you consider expensive, there are programmers on the net
that have free s/w and recommend h/w you can build yourself for
less than $10. ?
Not tricky at all to output serial, like stopping at a red light and
waiting for it to turn green, same principle just add a counter for
the number of bits, the rest is a sequence of events, do it by hand
for one byte if you like and you'll soon see its trivial. Just get
acquainted with the functions for count, jump, shift etc
Not willing to give my examples as it really depends on the processor,
it would be very easy to get misled and waste time, as you are new to
this I'd recommend doing it from first principles, though sure, you
can find examples on web through google, your time not mine.
Regards
Mike
* GMC/VL Commodore, Calais VL Turbo FuseRail that wont warp or melt !
* High grade milspec ignition driver electronics now in development
* Twin Tyres to suit most sedans, trikes and motorcycle sidecars
http://niche.iinet.net.au
