I am working on a new hardware design utilizing the Analog Devices
ADN8831 TEC controller.
We are having a problem with the ADN8831 going into cooling mode. We
are monitoring the VTEC output of the device and out2. When we
transition from 88.0 C to 44.0 C degrees, the VTEC pin does not go
above 1.25 volts (VTEC above 1.25 indicates the ADN8831 is in cooling
mode) but out2 goes less than 1.5. According to the figure 21 of
ADN8831 data sheet, when out2 goes below 1.5 volts, its should go into
cooling. We never reach the 44.0 C temperature.
In our design, PVDD = AVDD = 3.3 volts.
Heating seems to work as we expect.
Has anyone powered this device at 3.3 volts, the datasheet indicates
it should work down to 3.0 volts?
Any ideas why it will not cool?
Thanks,
Alex
Thanks,
Alex
