You had your answer several times. Please read the thread.
Ok I reread the thread, here are 4 answers I got.
1) If L and R would remain constant, the reactance and Q would double.
They probably won't stay exactly the same.
2) air core copper inductors (solenoids, etc.) go as Q ~
sqrt(F).
3) Double the frequency and you double the inductive reactance, while
keeping the resistance constant. So, the Q @ 100 MHz should be 160.
4) usually sqrt(f/f0) times the losses.
So instead of a non answer, how about being helpful.
If you knew the answer you could have copied and pasted it for me.
I think the real answer is, it is not an easy calculation, it gets into
the changes in skin effect, proximity effect, interwinding capacitance
and eddy currents when going from 50Mhz to 100Mhz.
Mikek
btw, What is your answer?
