Adjustiing/mod'ing digital thermostat on LG window air conditioner
Dan
Dan wrote:
I didn't note the model # but I just bought an 8000 BTU at The Home
Depot.
I tested it and it goes to 60 deg. I put a thermometer near the sensor.
gs
Thanks for the reply. I checked the temperature across the room on a
bedside table. Since the sensor is on the evaporator, it may very well
get to 60 right there, unfortunately it's a little cramped for living
space under the filter ;-) With mine set at 60, the lowest I could get
it in the room was 69, this on a day that wasn't more than about 74. I
attached a 100k pot in series with a 47k resistor across the thermistor,
adjusted to about 75k total (have to remove & measure to be sure) I was
able to get the room down to 61, with an outside temp of around 75. I
don't plan to keep the room this cool, but it does show the machine has
the capacity to lower the temp sufficiently if the thermostat tells it
to. Very easy mod, in case anyone else has a similar issue with a room AC.
Thanks again all who replied.
Dan
I
ian field
Mike Berger said:
The very energy-efficient models do work like that, and take
forever to cool down a space. For your purposes you would
probably be happier with an inefficient model, and you might
need to size it up.
Energy efficient my arse!!! - they chug away drawing 9kW for bloody hours to
drop the temperature 1C. Its not about energy efficiency, its about non-CFC
ozone friendly refrigerant that's next to useless!!
