is the front side of the tape copper or other electrical conductive material? is the backside covered with electrical conducting adhesive sticky enough to hold a small gauge conductor? can it be cut with a shear? does the foil read 0 ohms front to back? can it be folded over a non conductive material? folded over so the wire is in contact with the copper either through or not through the adhesive or copper directly? I am a newbie with this stuff. I ask because I need to make a unique contact to match the existing mating contact and foil is the only way to do it, unusual space and twist and turns. the two ribbons will not short, plenty of space in between. the foil will carry 24 volt dc up to 20 amp, probably less. any advice welcome.
Platforms
Content
