Hi
I recently bought a new lawn tractor, and will be using it to snow blow my 150' driveway this coming winter.
Here she is:
My plan is to add two sets of lights to the tractor (total of 3). One set in back for backing up, and one that I'll be mounting on the snow thrower itself. I want to use 3 switches total. All three will be illuminated switches (ground, power, accessory).
Currently the tractor has two headlights (see photo).
The tractor also has some kind of alternator in which the main headlamps run from. Meaning, they won't run unless the tractor is running, and if the throttle is low, they are dim and when the throttle is high, the reach full brightness. I don't really mind this and if its healthier for the battery, I am ok with having the two new sets of lights run on this same system. My guess is the other option is to have them run right off the battery?
Here are some questions:
- First of all, if the alternator is putting charge back into the battery, then what is the point of having the lights run through the alternator? My thoughts are that if they are drawing X amount of energy then what's the difference if its coming from the battery or not as long as the battery is being replenished. The only thing I can think of is that their energy use is 'scaled' or limited with the throttle, so perhaps that keeps the battery healthier, but I'm not sure.
- Next, how do I wire this up?
Right now the tractor has a single switch to control the headlights (2 prongs). I want to eliminate this switch and use 3 illuminated switches (3 prongs). One switch for the main headlights, one for the rear light set, and one for the set on the snow thrower.
The main headlights have 2 wires going to the first light, then from there two more wires go to the second light and thats the end of the road.
Looking forward to hearing back and I hope this is the right kind of forum!
Cheers!
![wavey.gif](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-raQSRrdo64s%2FTmRa-mPEVYI%2FAAAAAAAAExU%2FTDcQ-_TIp6k%2Fs800%2Fwavey.gif&hash=581cc4c1d6f8c0eb6e95a21faeae4c30)
Here she is:
Cheers!
