Hello there!
For a school project, I am creating a simple data acquisition system which uses a frequency to voltage converter to sample a frequency and then display it on an LCD screen on my PIC 18F4685 board.
I have created the frequency to voltage converter in such a way as that it outputs a voltage from 0-5V for an input of 0-1000Hz.
When I attach this frequency to voltage converter to the ADC pin (RA0) of the board, the voltage drops from 5V to 4.7 volts (as seen on a multimeter and the LCD screen). To fix this, I added a buffer circuit which consists of a voltage follower (with an op amp). However, this buffer actually makes the problem worse - that is, it drops from 5V to about 0.6 V.
How can I create this circuit so that the PIC board does not load it so much?
Thanks for any ideas.
