Hi all,
I have an active high signal on an IC. This puts the IC into shut down mode. It is connected to an I/O line of a PIC.
Can i connect the shut down pin to OV via a 10K pull down resistor, this makes the IC active. Then output a logic 1 from the PIC to enable shut down i.e. making it high Does that seem correct?
Thanks in advance
Thanks in advance
