I think there would be plenty of power there, harnessing it in a sensible way is a bit of a challenge. You can probably live with an average power consumption under a milliwatt.
I might charge a small capacitor (say 1uF) and use it to power a Schmitt trigger which extends the pulses it receives (essentially straight from the audio). the output is used to switch a mosfet. If this is isolated with a transformer, it should operate as a switch.
The interesting behaviour would be during power-up. As the capacitor discharges, the mosfet will already be off and presumably the Schmitt trigger will have control of its outputs until the capacitor voltage drops below Vgs(th)
it might fail the OP's idea of "simple" though.
