Hi, guys. I'm new here. Forgiveme if this is too newbie.
I have a relay that I want to switch on using one of the output pins on the parallel port.
This is what I've got:
The relay is powered by a 5V DC adapter and the transistor should act as a switch.
But i dont know where to connect the parallel port's ground pin.
If I just connect the 5V pin to the transistor's base (like the diagram shows), it doesn't work.
