Sorry, this is very probably a very stupid question & I am sure I'm missing some fundamental concept but here goes.
In say an audio amplifier an AC signal can be superimposed on a DC offset/bias, or some explanations say the AC is riding on top of the DC. I get that now the signal is moved away from 0v & is offset, useful for amplifying if say your only using a single supply. I understand this bit. However I'm having trouble understanding how this fixed DC component is still intact/present as DC after the AC signal is applied. On a scope if you apply a signal to a fixed DC bias voltage the DC appears to change into the AC signal & you can now see & measure the peak to peak value (instead of the flat fixed DC voltage line that was there before the signal was applied). How is there still a fixed DC voltage present when the scope now shows just AC ? How does the AC signal interact with the DC exactly & how can they both be present ?
