about hFE multimeter test...
ArameFarpado
Hi all...
a transistor "BD435" is giving me 440 in hFE test on the multimeter, when
the tecnical data i've found tell me min=40 max=475...
does this mean the transistor is really in good shape?
can it be busted and still give a good hFE test result on the multimeter?
thanks
ArameFarpado
Baron
ArameFarpado said:
Hi all...
when the tecnical data i've found tell me min=40 max=475...
multimeter?
thanks
ArameFarpado
It means it is within spec !
ArameFarpado
Em Sábado, 19 de Abril de 2008 20:18, Brian Gregory [UK] escreveu:
It depends how good the multimeter's Hfe function is. Agreed
Check that if you disconnect B and connect only C and E the meter shows
either a low number (ideally 0 or no more than 1 or 2) or an error of some
kind.
connecting just E and C in the socket, it reads the same value for hFE.
so, it got me thinking that hFE measure is not a transistor test for
working/burned transistor...
do you use hFE measure to see if a transistor is busted?
thanks
ArameFarpado
