Hi everyone. I am new to this forum, and a complete newbie to everything electronics. I really hope that someone can help me, and this will probably be a straighforward question.
What I want to do is as follows:
There are 2 push buttons, A and B.
• When button A is pressed, a motor turns clockwise until it reaches a set point. (Button B is deactivated at this point so pressing it has no effect).
• The power to the motor is then automatically cut after a set point is reached so the motor stops.
• Button B then becomes live and button A is deactivated.
• Only when button B is pressed, the motor returns to the exact point it started at to begin with.
Is it possible to automatically cut the power to the motor (in both directions) when it meets a point of resistance?
Many thanks for any help you can give.
By the way, if it helps, this would be for a custom pop-up headlight mechanism I am devising.
