A Non-friction bicycle lights generator (dynamo)
In this new generation bicycle light system, no battery is needed, no
friction on any parts of the bicycle. The lights flash regardless speed
of the bicycle and weather conditions (unlike normal dynamos!). Very
bright.
It can be used as a stand-alone light system (as a normal dynamo) on
your bike, or used as a back-up for your existed battery-powered lights
All details and buy on-line: http://www.freelights.co.uk
Jim Thompson
bright.
Barf. No drag at all means no power transferred... there has to be
SOME drag.
...Jim Thompson
John Larkin
SOME drag.
...Jim Thompson
They admit to a very small drag. But the flipping-magnet scheme is
very clever, and as they point out there's very little mechanical
power required, and no friction like wheel-contact generators have.
I like it.
John
N Cook
I like it.
John
When i were a lad i had a bike with a dyno-hub and hub brake.
No back torque from the dyno-hub unless the lights were switched in and both
generator and brake were pretty imune to rain.
IIRC there was no limiter on the dyno and would blow bulbs if i went down
hill too fast..
Martin Riddle
I'll stick with my 6v halogen lamp and 4 NIMH batteries. Lasts 4 hours and no drag.
Cheers
Doug McLaren
| and no drag.
.... and I'll stick with my light with 3 really bright LEDs. Runs
about 15-20 hours on four AA NiMH cells before it gets dim enough that
it doesn't help me see (but it will help me be seen for perhaps 60
hours of use) and again, no drag. (Though my goal is mostly fitness,
not transportation, so drag isn't such a problem, but even so, it's
nice that it's not there.)
The lights with LEDs are really nice. They're really bright -- some
being as bright as your halogen lamp -- and last a very long time.
And vibrations won't break the filament.
Mine last so long that the self discharge rate of the NiMH cells would
be a larger factor than the current drain of the lights themselves for
a normal person -- except that I do about an hour of riding each night :)
(So yes, I only have to charge my batteries every two weeks or so.)
Barry Lennox
From the website:- "No Friction! No Resistance!"-- That statement
looks like false advertising to me, I'm surprised the UK consumer laws
do not apply. Or have they cracked the laws of Thermodynamics?
I was looking on their website for perpetual motion machines and
water-powered cars, but I guess they are still under development.
Barry Lennox
K
Kryten
They admit in the small print that
"technically there is some resistance"
and I think the word "technically" is redundant.
If there is some, they cannot say there is none.
In practice I suspect there is no noticeable resistance because it takes out
so little power.
I prefer the national grid providing the energy for my batteries for my
lights, rather than me.
But the flipping-magnet scheme is very clever
It doesn't look a very efficient way of converting mechanical energy.
Their animation looks very vague indeed.
Perhaps deliberately so.
I like it.
I got the impression that LEDs do appear very bright light sources when you
look at them directly, but they don't seem as good at illuminating the path
ahead due to their lower light output. I think the human eye can't perceive
a great difference between two point sources near the upper end of perceived
brightness very well.
I heard it is also a myth that LEDs are more efficient than filaments.
Efficiency of the latter varies with voltage and current.
Low voltage bulbs (e.g. 2.5V) have to pass the most current, so the filament
has to be thicker, hence there is more heat conducted along and out of the
wire. And also more resistive losses from wiring and internal resistance of
the batteries. On the other hand they can't make the filament too thin
otherwise it will break too easily. One can buy bike light bulbs designed
for 6V batteries, but I have not seen any for 12V.
Filament efficiency also drops as the battery voltage drops below the bulb's
rated voltage: the filament does not get hot enough to radiate visible light
very well, but still manages to radiate energy in infra red - depleting
batteries for less light output. Nickel cell voltage droops worse than
alkalines or zinc-carbon.
Ben Bradley
bright.
For a moment I thought it might use Wiegand wire. And I can't
believe I DL'ed a 6 meg video to see a magnet flip around.
Googling for that posting address shows this poster doing a lot of
low-grade spamming to only "relevant" groups, apparently trying to
stay under the oh-its-spam-lets-nuke-em radar.
Looking a little more, not everything he's posted is spam, in this
post he's actually asking for some help in getting this thing
manufactured:
http://groups.google.com/group/[email protected]&rnum=5&hl=en#47af16908e8ca9ee
I would actually have some respect for the guy if he didn't use
Usenet newsgroups for his free advertising.
Hmm, I just read his post on alt.cad.autocad, and the "appropriate
responses" he got to his question, it's fairly amusing.
K
Kryten
Okay well it is _mechanically_ frictionless but it will have the same
retarding effect. Only very little because it is so weedy. I expect someone
else can see a small white LED but they are not enough to illuminate a path
ahead.
I think the main reason the guy wants help promoting it is because it isn't
sufficiently better than existing products.
Now if someone made a system that used the energy wasted while braking, that
would be a good idea. Not only do you need the normally undesirable
friction, you need a lot of it. Going up a hill, you turn it off. Going down
a steep hill heading toward a red light, you turn on your high-geared dynamo
to top up your batteries.
Obviously this is no substitute for real brakes, but a lot of times you can
see you need to slow down way in advance. Maybe you could have a two-stage
brake: grip lightly to engage the dynamo, grip hard to apply brake pads.
This technique is used in some electric vehicles, and known as regenerative
braking. there it puts energy back into the batteries that drive it.
I'd have respect if it was a really hot product.
As it is, it is really lukewarm.
Dirk Bruere at Neopax
ahead.
Does it have a big fat cap to store a decent charge?
Does it trickle charge a battery?
Dirk
The Consensus:-
The political party for the new millenium
http://www.theconsensus.org
