I want to connect PIC16F690 (http://ww1.microchip.com/downloads/en/DeviceDoc/41262C.pdf) with 7seg display. Have got this model: ELT-511SURWA/S530-A3 (datasheet: http://www.datasheets360.com/pdf/-3210061775093412092)
Forward current-Max: If = 0.025 A
Forward voltage-Typ: Vf = 2 V
R = (5-2)/0.0250 = 120 Ohms (150 Ohms, if If = 0.02 A)
Resistor wattage:
P = I * V = 0.02 * 3 = 0.06 Watts
Is this correct calculation for current limiting resistor value for anodes of the display?
I'm going to multiplex these segmets (only two of three digits will be used). Idea is to use two NPN transistors to sink current from each of the two common cathodes.
8 * 25 = 200 mA current for the collector. It means I need ~20 mA base current, but maximum output current (any I/O pin of PIC) is 0.025 A. So can I use any NPN transistors which are rated for 200mA collector current? Have read before, when comon cathode 7seg display used, we need PNP transistors.
Resistor wattage:
