Computer Nerd Kev
Hello,
I am working on a circuit in which I want to use 74164 SIPO
Shift Registers as something like basic DACs (Shift Registers
outputting a stepped current).
Whatever you want to call it, it involves connecting the
outputs of the 74164s together through individual high value
resistors so that current increases with each output going
high, the parallel output driving the base of a transistor. I
couldn't see a problem with the idea until I read this line in
"Newnes Digital Logic IC Pocket Book" (P. 44):
"Note that normal totem-pole outputs should not (except in a
few special cases) be connected in parallel."
Nothing is said regarding what these "special cases" might be,
although if viewed from the perspecive of logic interfacing, I
can see how mine may be one of them. Indeed it seems likely
that the statement refers to cases such as in a wired-OR
circuit where outputs are connected directly, without series
resistors.
Nevertheless, I saw need for clarification so I searched books
and the internet for reference to TTL totem-pole outputs in
parallel, but found nothing to directly address my concern.
Hence I ask here for clarification on the matter.
resistors.
