Hi all. I have built a clock circuit that uses 4017 decade IC's to divied the line frequency down to a usable clock pulse. Basically, one 4017 divides by six and another divides by ten rendering 1 Hz. Then a chain of 4017's go on to perform the counting function. My question is this, what, other than slow alternators would account for a slow clock? I could see that noise may introduce rogue pulses and make a clok fast, but the only thing I would account for a slow clock would be a slightly underspeed line frequency.
At any rate, I have sort of kept an eye on the frequency with my oscilloscope (which has a frequency function) and my observations tend to agree with the slow alternator theory. I am measuring from the 10 Hz portion of the circuit. I see constant fluctuations. A lot of the time, I see a perfect 10, other times I frequently see 9.983 and sometimes 10.02.
I did a little research and found that there is a strict frequency standard that must be kept by all (at least North America) power generation facilities. Apparently, each day the alternators and gear must be adjusted to compensate for any underspeed/overspeed situations that may effect timimg functions. After a couple of days, my clock has lagged the computer clock I have it synched with by nearly four seconds. I figured to see an up and down slight fluctuation over a day or so, with it averaging back out, but so far, it's just running slower.
I will go ahead and post the schematic here. I have made a few changes. I am using a 6/0/6 stepdown transformer. I then rectify the 12 volts with a bridge and then onto a 9 volt linear regulator. I am also using a seperate power supply I built to deliver the HV to the display. Those are pretty much the only modifications I've done, the dividing and counting part of the circuit has not changed.
