My plan is to use the module below to act as a UPS switch for my small USB powered device.
Parts will include:
1 x dual port USB Female 2.4amp AC adapter plug. = Source to Male USB cord to PCB
1 x 10,000 mah USB battery pack. = Battery to Male USB cord to PCB
2 x USB 2.0 Male (cords cut and split from old parts)
1 x USB 2.0 Female (cord cut and split from old parts) = USB Device (male) to USB Female to PCB load
I planned to charge the battery separately. Can this be done as I plan? Anything I need to know or add for this? Should I use an AC cord with transformer for source? Should the Battery be actual batteries, or can I use one of those $10 packs from amazon. I say this because I think this module can charge a battery as well, and the packs usually differentiate charging vs draw ports.
Thank you!
https://www.amazon.com/Battery-Switch-Automatic-Emergency-Controller/dp/B07X42Z64V
- SPECS OF THE BLUE RELAY CHIP -
Model: SRD-5VDC-SL-C
Coil voltage: DC 5V
Coil resistance: 70Ω ~ 80Ω
Contact resistance: 100Ω Max
Operation time: 10msec Max
Release time: 5msec Max
Ambient temperature: -25°C to 70°C
Operating humidity: 45 to 85%RH
Operating current: 43mA ~ 46mA
Release current: 15mA ~ 18mA
Pin: 5Pin
Insulation resistance: ≥100M (Ohm)
Dielectric strength:
Between coil & contacts: AC 1500V 50HZ ~ 60HZ/min
Between contacts: AC 1000V 50HZ ~ 60HZ/min
Rated load:: 10A 250V AC / 10A 125V AC / 10A 30V DC / 10A 28V DC
Size: 1.8 x 1.5 x 1.6cm (L x W x H)
Parts will include:
Thank you!
Coil voltage: DC 5V
Pin: 5Pin
