Hey guys, I have purchased a couple of controllers now which all come with a cheap little remote, however the remote always seems very temperamental and doesn't always work.
I have modified the circuit very slightly however, but to only extend the cables and change connectors. Currently I have got this controller. It appears to be the same for all the others, this is what I have got now with the modifications I have made:
As you can see I have extended the IR sensor a bit, could this be the problem with my remote not working very often?
Is there any 5050 RGB LED controllers you would recommend, they need to be small however due to this going on my motorbike, im encasing the circuit board in resin once it works.
