Dorian McIntire
Paul Keinanen said:At least in Europe, all tube televisions and many tube radios had a
universal (AC/DC) power supply, with a half wave rectifier generating
the B+ line about 200-250 V, thus there was only a rectifier between
the other mains plug terminal to the B+, while the other mains plug
terminal was directly connected to the metallic chassis. Depending on
the way the mains plug is inserted into the wall socket, you either
have the Neutral in the chassis or the full 220 Vac Live in the
chassis. Also the tube heaters were in series and across the Live and
Neutral, possibly with a VDR in series to limit the inrush current.
When working with such equipment I have used two main principles,
before starting to work, I _always_ checked the mains plug orientation
by measuring the metallic chassis voltage. When working with active
equipment, I put my left hand in the pocket and only work with my
right hand inside the equipment. This avoids the risk of having the
current flow through your heart. If you get a muscular cramp in your
right hand due to an electric shock, you still have the left hand
operational to cut the power.
Regarding low power devices powered by a series capacitor, I would
suggest using capacitors intended for mains filters.
Instead of a single capacitor on the live side, put two in series,
each connecting one side to the respective mains plug terminal, while
the other terminal of each capacitor goes to the load (rectifier
etc.). In this configuration, the small signal circuit is floating
around 110 Vac. If you accidentally touch the small signal circuit,
there is still the other capacitor in series between the mains voltage
and you, limiting the current through your body. If you want to limit
the worst case current to 30 mA, the normal circuit current
consumption must be below 10-15 mA, since in normal operation, there
are two capacitors in series.
Paul
This is a good idea because it also provides double protection against a
capacitor short failure. Also due to the possibility of such a failure a
series, low current fuse is advisable.
Dorian
