absolutely not! But it is probably one of the easiest ways to attached a clock pulse.
Ok..It is not necessary but it is one of the ways to have the clock pulse given to the 4017 right ?
No, re-read what I said and what steve said. YOU MUST HAVE A CLOCK PULSE for the 4017 to work, but a 555 is most certainly not the only way to provide a clock pulse.
edit: I ain't sure how to take your comment. But the 4017 needs a clock pulse as steve said. Sorry if I misinterpreted what you meant
Hey, whats for we connect diode to combine two or two output Q?
I don't understand what you're asking.
Same here.
Vick post your diagram. I hope we won't be discussing internal circuit of IC.
The circle part in the diagram is what I referring to..why do we connect diode to combine the output pins? Can I just connect them using normal wire ?
The diodes are necessary since if one output is high and another is low, they will fight to determine the output voltage. The diodes give a high output when any output is high.
This was already answered by duke37.
Oh you want detailed or step by step explanation. Let's wait for other members to post. They have better english and knowledge than me.
Good question Vick5821.
Remember that CMOS outputs can source and sink current.
If you connect 2 of them together and they have different logic levels, you will force current from one to the other. This is almost always *not* what you want.
The diode ensures that current cannot flow back into the other outputs, and effectively wire-or's the outputs.
You should also look at open collector (or open drain) outputs as they provide another solution to this problem, although it soed not apply here because the 4017 has normal outputs.
In a 4017, only a single output is high -- think of it as connected to V+
All the other outputs are low -- think of them as connected to V-
Imagine what happens when you connect V+ to V- -- because that's what you do when you connect two logic outputs together that have different levels.
Fortunately for your power source, the outputs have significant resistance, but you should still be able to see what happens.
