4-Channel IR Circuit Help! :( - Urgent
Ok here it is....I have a project in for Thursday, ive been tearing my hair out for weeks trying to get this to work. My problem is:
Button 1 + 3 moves motor A clockwise.
Button 2 + 4 moves motors A + B clockwise.
Motors latch, it should be momentery, stop when button is let go
It is supposed to:
The buttons should be momentary
Button 1 should move motor A one way
Button 2 should move motor A the other
Button 3 move motor B one way
Button 4 move motor B the other
And be momentary.
Are my positive wires position causing the problem?
Will
You've told us what is supposed to happen, but not what actually happens.
As far as I can see you've implemented an H-Bridge using relays (which incidentally is exactly what my garage door opener uses).
Have you tested that your IR remote can transmit signals for 2 buttons pressed at the same time?
Is this your homework? Have you left it too late?
Why do you want to use 2 buttons when 1 would seem to suffice?
Relay 1 and 3 make sense. Are relay 2 and 4 for a second motor?
It is degree c/w. The intended result was:
Switch 1 rotates motor A left
Switch 2 rotates motor A Right
Switch 3 rotates motor B left
Switch 4 rotates motor B Right
It is to opperate a household spotlamp to aim to any point in the room.
what actually happens is:
Switch 2 rotates motor A + B left
Switch 4 rotates motor A + Bleft.
Im not sure if the positive off the relay is going to the correct point. It has to got to a positvie so I stuck it to the closet 6v
Will
