Hi, working on a project, I've got a wire string of 20 red led's running off 3 x 1.5 v aa batteries and I need to be able to run them off a 12volt LED driver. Where can I find some info on calculating the resistance? Or am I looking to the wrong solution. Thanks for any help.
An LED driver is usually constant current then it adjusts its own resistance.
Set the LED driver's current for the brightness you want and use as many LEDs in series in each string as their max forward voltage and the minimum output voltage of the LED driver allow.
I was thinking specs.....anyhow, what is it you want to do exactly, run off a 12v supply..?
I cannot see any control board in the battery casing.
If so, just run off a dc dc down converter set to 4.5v.
I'm trying to create a special effect of dragon fire. I've got two pc fans creating the wind and I need red LED's to light it. The fans run off 12v so I'm trying to run the lights of the same driver as it is on public display and I don't want to keep having to go and change the batteries. Do you mean one of these?
Curious thing, when I disconnected the lights from the battery box there was a resistor on the negative side, I think it was 570 ohms. How does that work?
570 ohms is not a standard resistance.
LEDs must have a resistor or circuit in series to limit the current. Without the resistor then an LED will burn out immediately when a voltage too high is connected to it.
The white LEDs use about 3V and three new batteries produce 4.5V. Then the voltage is 1.5V too high and is high so that the LEDs still light when the used battery voltage drops to 3V. Ohm's Law calculates the current. 1.5V across the resistor divided by the max current you want is the resistance needed.
OK, I'm confused, how come when I connect the 20 leds to a 3v cell with no resistor they light up? I don't understand why I cannot connect to a 12v dc supply with a resistor on the positive side. Basically I haven't a clue.
A cheap battery cannot produce a high current. The "Super Heavy Duty" AA cells from ebay are mostly full of rice.
An expensive Name-Brand battery produces enough current to explode LEDs that do not have something to limit the current.
Oh, maybe your 3V battery is a little CR2032 coin cell that is too small to produce a high current.
If course you can use 12V and a series resistor to limit the current so that the LEDs do not burn out.
But then the resistor will get VERY hot wasting a lot of the battery power.
Admittedly the cr2032 does not give enough power to make the leds very bright but it lights them so I would have thought that there was a way of lighting the 20 (0603 I think) leds with a 12v dc supply.
The CR2032 doesn’t supply much current at all, hence no resistor required.
The 12V OTOH can. Series current limiting resistor will be required.
It if worked on CR2032 but doesn’t now on 12V, you probably killed the LEDs.
