So I'm messing with a 1st order, low pass RC filter, and the break freq is at 100Hz. Measure it with the scope - attenuation is perfect (or within 1% anyways), but the phase difference is only coming out at -39.2 degrees.
Now I know this happens with RL filters because of the DC resistance of the inductor, but with an RC filter, this shouldn't really happen (as far as I understand anyways). I tried multiple cap values, changing the R values as needed to maintain the break freq and no change. The only way that I can get the phase to agree (within reason) of -45 degrees is by moving from an electrolytic cap to a ceramic cap.
I'm assuming that this is an ESR related thing, but in order to get the phase to be close in my calculations / simulations, the ESR has so be 18-20ohms on a 10uF electrolytic cap. This is roughly 20x the documented average for this value. I've tried multiple values, voltage ratings, and mfgs, but it always has this odd ball phase shift.
What am I missing here? What is it about electrolytic caps that cause a goofy phase shift?
I attached a bode plot, and scope reading at 100Hz, of the physical circuit so you can see I'm not imagining this. In my use, the phase shift really doesn't affect anything, but it still peaked my interest. Any ideas?
