P E Schoen
You're probably getting tired of this but I've come up with a simulation
that seems like it should reasonably match real-world performance. I added a
0.5 ohm precharge resistor which is bypassed with an NMOS FET when the
output exceeds about 200VDC, and it greatly reduces the initial inrush
current and high power levels seen previously. I found that it worked better
by eliminating the inductor at the output and relying only on the leakage
inductance, which I simulated with two 20nH inductors in series with the
primary legs. I tried various ways of dealing with the high voltage
transients but two RCD snubbers seemed to do the job. At close to 50% duty
cycle the rectified square wave is almost pure DC and the 40uF output
capacitor smoothes the output well enough during the approximate 2 uSec dead
time at 16 kHz.
I had another design which used a MOSFET and some zeners as a 66V high
current shunt regulator and it seemed to work well also as a snubber. I
could also possibly use some TVS diodes.
For a practical design I might use a relay in place of the precharge MOSFET
switch, but it would need to handle over 100A and a couple of MOSFETs (or
even one) should work. There are lots of inexpensive devices with 2 mOhm or
less and voltage of 30-40V which should be enough. So here are the
simulation images and ASC file:
http://www.enginuitysystems.com/pix/24V-300V_CT_Final-1000W.png
http://www.enginuitysystems.com/pix/24V-300V_CT_Final-1000W-20mSec.png
http://www.enginuitysystems.com/pix/24V-300V_CT-16kHz_Final-1000W.asc
Now I suppose I'll need to build the thing and see how it works. I'll try to
take better inductance readings on the transformer first, and then re-run
the simulation if needed. I'll also probably add some current feedback and
shutdown in case of overload.
Paul
time at 16 kHz.
Paul
