I have a question that i would like to run past you.
I have a device that uses a 230v PCB mounted transformer. EL30 casing.
The transformer has 2 pin for input, live and neutral, and has 2 outputs, 12v each.
I would like to allow this device to work in the USA which uses 115v. Can anyone see a problem with using a 230v transformer with 2 x 24v outputs. As i would be supplying half the voltage then i would get half the voltage at the output, giving me the 2 x 12v outputs.
Is there anything wrong with this approach?
