Sir Nauman Muhammad . . . . . . .
I will also try this one Will 7.6 Ohm resistor work?
Unless you typed in the wrong numbers above
NO WAY would as low of a value as 7 decimal 6 ohms be used.
Sir duke37, was interpreting the 2.2K and 3.3 K as actually being the units existing R7 and R6 values, while that was not their values..
Actually, those were two very commonly found values, that one could salvage from surplus electronics.
In reality, the idea was then to use THAT pair to shunt across the EXISTING R7 and R6 pair to see the degree of voltage change.
In your case, you actually pulled out the R7 resistor completely, and installed your 6K combinational pair in place of it..
Which is OK, as we saw that the power supply then produced 7.5 volts instead of the original 12.54.
And
YES, you need to pull that resistor pair and
reinstall the original R7 10K resistor before moving on to work with the R6 resistor.
AND as I suspected, and had mentioned before, is that the change / altering the value of that R6 resistor is the one that seems to be the one that is going to get the voltage change that is needed.
OBSERVATION:
Made from post #9 's photos.
In looking all around the board, we see the use of resistors using the common 3 band color coding.
In the case of the R6 and R7 pair, which are being used to produce a more precise trimming in of of the zener voltage created with that IC2 . . .K431 . . .shunt regulator.
They are using more precise value resistors, with those two resistors seeming to be using a 4 band color coding.
HOWEVER that is not what my eyes color perceptions seem to be on those two resistors.
When I look at R7 color codes, I immediately want to see it as a 100 ohm unit with my eyes only seeing
BLACK and BROWN bands . . .with no RED's or ORANGES ?.
Now with you ohmming it out with your meter, you are saying it is being 10,000 ohms.
Now I know that my "read" of 100 ohms is far too low or even up it to 1010 ohm reading, if using 4 bands.
However, that 1010 value could then be a possibility at the low end of possible values.
I would expect it to be up in the 1000's of ohms, with that 10 K being on a possible high ranges end. Which seems to be the case.
So what needs to be done, is to initially pull your next resistor to be involved, which will be R6 and use your ohmmeter to read its value.
I see color bands of ORANGE BLACK RED YELLOW.
Which could read out as 3K if using 3 band color coding
I would expect it also to be up in the 1000's of ohms . . . . which that would be . . .but let's just find out what you actually are reading..
73's de Edd
