That is because you are not putting a bias voltage on the + pin with that circuit, you are putting a current into it.
You need two resistors, configured as a voltage divider to set the bias.
If you keep the 100K resistor, try a 47K resistor from the + input to ground. This will give you a bias of 1.6V.
Bob
Bob
