Larry W4CSC said:
Which type of emissions is that? The Synctillation counter I had was
the same one used on nuke subs at the time. Are there quarks or
exotic isotopes of Cornucopium radiating from plain old thyratrons??
Our ship was powered by sweat and bunker C oil you had to boil before
you could spray it into the 1945 boilers. We had some clocks with
radium dials, though...(c;
Larry W4CSC
POWER is our friend!
They were slightly radioactive, even broken, but not so much that any
"geiger counter" could detect anything. We used instrument hundreds of times
more sensitive on submarines, and measured air, urine and swipe samples for
alpha, beta and gamma detection, accordingly. Some of those processes
involved superheating the pressurized samples in equipment that detected
levels to small to be discussed. And of course we wore two different types
of personal-detectors, according to the area of work performed on the boat.
As to disposal of broken tubes, even today, your method seems acceptable to
everyone except the frantic and frustrated emergency drill inspector, who
I'm sure never forgot you.
FAA radar tube disposure methods: I had a good laugh when I saw your idea
here ;-)
(1) Handling. There is no external radiation hazard due to normal handling
of radioactive electron tubes.
(2) Storage. Exercise judgment and caution to avoid large quantity storage
and possible breakage. Under no condition shall random storage in boxes or
bins be permitted. All storage areas for large quantities of radioactive
tubes, such as the FAA Depot, shall be clearly marked with radiation warning
signs as described in paragraph 24.d.
(3) Decontamination. In the event of breakage, decontamination shall proceed
as follows:
(a) Dust. Avoid agitation of dust in order to minimize dispersion of the
radioactive material. Internal exposure by ingestion and/or inhalation
should be avoided. Should either or both occur, contact the cognizant
Aviation Medicine Office.
(b) Tube Fragments. Retrieve tube fragments with forceps or pliers and
dispose of them as normal waste. Clean instruments with a dampened cloth. If
forceps or pliers are not available, use gloves and dispose of them
immediately after use. Do not handle tube fragments with bare hands.
Jack
former mushroom-cloud farmer
