If the metal case of a pot picks up electrical hum then it will feed the hum into the circuit. But if the metal case is connected to the circuit ground then there will be no hum produced by the pot.
Since the output impedance of the preamp is much higher than all other preamps then the output level will be less and maybe distortion will be increased with the pot values we show.
I think the spec's for the K&K preamp means its output can feed 10k.
I thought that Alec_t in his diagram had supposed that I knew that the lug 1 must be welded on the metal box, and for this he did not put it.
I know that it must be welded on the box but I asked for be sure 100%.
I need that you tell me exactly everything, even where the gnd must be welded.
Now, after only 6 hours, Fishman's support has answered me, the output impedance of the Fishman 501 T is 3.5kOhm.
For the K & K pure preamp wr do not understand what they mean with 10kohms, it seems too much, but I downloaded it from the official website.
At this point what do I do? I can not tell you the input impedence of the P.A.s, I can only tell you the output impedence of the Fishman 501T.
It's not important for me that it's perfect, the important thing is that it is safe.
If you did not tell me you I would have directly connected the two outputs on the endpin directly.
If for safety I put 2 resistors a bit higher for each preamp what can happen?
What do I lose a bit of volume ??
The important thing is that is safe.
Thx
regards
