I've plugged it in and it shows no signs of life. The fuse is OK. The capacitors look good. I've tested a number of the diodes on the board and they're OK.
When you plug it in, the red LED should turn on and stay lit solid. It doesn't turn on. I've tested both the green and red LEDs and they work.
Please point me in the right direction of what to test. I have a multimeter with diode tester as well as an ESR capacitor tester.
