hi everyone! not sure if i will find anything on this forum but thught i'd ask as i was already a member.
Basically I have a board and a screen which I am trying to install in my car for ecu data-logging purposes (small screen in sunvisor would display oil pressure, batt voltage, boost pressure and loads of other stuff thanks to my evoscan software)
The board I have to drive the screen i believe is out of an in car DVD player so I imagine is for 12v. The board also has what i have determined to be a mini din-9 plug which looked exactly like my old sega mega drive 2 plug so i went and bought the cable on ebay and IT FITS!
However, the cable I have is mini din 9 to RCA (yellow, white and red) so the RCA end probably has no means of power input whereas the mini din 9 looks like this:
Sorry that's the best I could find. But as you see it needs a voltage input which I don't believe the RCA has?
Is there another cable I could buy to make my life easier? I am not capable of soldering to a board but i can solder wires together ok so I could buy a cable, cut it and take the wires to the 12v, ground and video input?
If it helps here are some pictures of the board:
Edit: I found this link a while back, it tells me what pin is what but doesn't help me too much with a solution... the guy i bought it from claims is worked on 12v but if it is only for 9v i dont want to blow it so would need a resistor in there somewhere, but i obviously don't know what current the setup will draw... any ideas?
