Virtual Pi Pico simulator from Wokwi presents you a basic Servo motor drive example along with two LEDs
Raspberry Pi Pico simulator from Wokwi is used in this project. You will learn how to drive the servo motor and also drive two LEDs connected to the Pi Pico in Arduino style programming.
Pi Pico simulator connection diagram
You will need following items
- Pi Pico (Pi Pico emulator will do)
- Servo motor
- LEDs x 2
- Connecting wires
Raspberry Pi Pico simulator projects - Servo motor control
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
void setup() {
myservo.attach(0); // attaches the servo on pin 9 to the servo object
pinMode(1, OUTPUT);
pinMode(3, OUTPUT);
void loop() {
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
digitalWrite(1, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(2, LOW); // turn the LED on (HIGH is the voltage level)
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(1, LOW); // turn the LED on (HIGH is the voltage level)
Pi Pico simulation - Here is how the project looks
Wokwi Pi Pico simulator - Servo motor and LED drive
Live link to the Pi Pico project
https://wokwi.com/arduino/projects/303904623239889474?dark=0
Comments, feedback and suggestions are welcome
Please hop on to https://wokwi.com/discord or leave your valuable comments below. Please share a like if you found this information helpful. For more information on the the Wokwi Simulator head to https://wokwi.com or https://docs.wokwi.com
